    Qrevo Curv 2 Pro
    Power, Gracefully Delivered.
    Buy now
    From carpets to corners, experience truly powerful, adaptive cleaning with the Qrevo Curv 2 Pro—seamlessly paired with an advanced multifunctional dock that keeps your floors hygienic, your hands free, and your home healthier for the whole family.
    Industry-First¹ AdaptiLift Chassis
    Engineered for Redefined Dynamic Carpet Cleaning.
    Outstanding Cleaning Power
    25,000 HyperForce Suction² & 12N Dual-Spinning Mop System³
    Dual Anti-Tangle System
    Tangle-Free Cleaning, Always.
    Automatic Mop Detachment
    Mop detaches automatically to protect carpets from moisture.
    7.98 cm Ultra-Slim Design
    Cleans under low furniture with effortless ease.
    Hygienic Multifunctional Dock
    100°C Hot Water⁴ Mop Washing for a Deeper Clean.
    From Carpets to Corners:
    Deep Cleaning, Redefined
    AdaptiLift Chassis
    Climbs, Lifts, and Cleans Like No Other
    30% Higher⁶
    Dust Pick-Up Rate on Long-Pile Carpet
    Industry-First Dynamic Cleaning⁵ for Up to 3cm Carpets
    Experience industry-first dynamic chassis elevation with omni-directional wheels, the robot intelligently adjusts the body height to maintain optimal suction contact on carpets up to 3cm. This ensures deep, consistent cleaning on carpets up to 3 cm of varying pile heights—finally delivering on the promise of real carpet cleaning performance.
    4cm¹ Maximum Double-Layer Thresholds Crossing
    Prevent Getting Stuck
    25,000 Pa HyperForce Suction
    Next-Level Suction for
    Ground-In Dirt
    Conquer every surface with confidence. Boasting 25,000 Pa of ultra-strong suction—among the highest in its class⁷—it effortlessly lifts embedded dust and debris, even from dense, high-pile rugs.
    0 25,000 0 Pa
    Max Suction Power²
    Want to deep clean carpets or avoid them entirely? One tap is all it takes. Your robot adapts: stronger suction when cleaning carpets with the mop lifted, or precise edge-cleaning to skip rugs and keep them dry*. You’re in control of every room, every rug, every time.
    *These carpet cleaning settings need to be manually enabled and selected in the Roborock app.
    Upgraded Mopping Performance
    Flawless Finishes,
    Every Time
    Flawless Finishes,
    Every Time
    Flawless Finishes,
    Every Time
    200 RPM
    Spinning Speeds⁸
    12N
    Max Downward Mopping Pressure³
    Scrub away tough stains with dual rotating mops that apply up to 12N of downward pressure and warm water.
    Transition seamlessly from hard floors to carpets with an auto-detaching mop. When vacuum-only or carpet-first modes are enabled, the mop is intelligently removed, avoiding moisture transfer and keeping carpets dry, fluffy, and fresh.
    Liftable Brush and Mops
    Vacuum Only
    Mops detached
    Main brush lowered
    Mop Mode
    Main brush lifted
    Clean Carpet
    Clean Carpet First
    Usual Cleaning Path
    Mop detached
    Chassis lifted
    Mop lifted
    Chassis lifted
    No More Hair Hassles
    Long hair? No problem. The DuoDivide Main Brush and FlexiArm Arc Side Brush work together to actively reduce hair entanglement—even with strands up to 40cm long. Just enjoy seamless vacuuming from start to finish.
    DuoDivide
    Main Brush
    Hair Tangling Rate⁹
    Hair Removal Rate¹⁰
    FlexiArm
    Arc Side Brush
    Hair Tangling Rate¹¹
    FlexiArm Technology
    Corners, Cracks, and Edges—Covered
    Roborock's exclusive FlexiArm Arc Side Brush and Edge Mopping System reach into hard-to-clean crevices and along walls, delivering unmatched edge-to-edge performance and full perimeter coverage.
    Edge and Corner Coverage¹²
    0mm
    Along the Edge and Corner¹²
    It cleans. Then It cleans itself.
    It cleans.
    Multifunctional Dock 3.0 Hygiene+
    100°C Hot-Water
    Mop Washing
    100°C Hot-Water Mop Washing
    Up to 100℃⁴
    Bacteria Removal Rate¹³
    Using up to 100°C hot water⁴ , our Multifunctional Dock 3.0 Hygiene+ helps loosen stubborn dirt, food residue, and greasy stains from the mop pads. With every wash, mops are refreshed more effectively—supporting a more thorough and hygienic floor clean.
    New Cleaning Tray with New Soaking Mode*
    Lower-Maintenance¹⁶
    Cleaning Tray
    The upgraded one-piece cleaning tray eliminates the need for a separate cleaning rack and scraper, increasing the contact surface with the mop. With a larger mop-covered area¹⁴ and greater water capacity, it delivers better mop washing, quieter cleaning sessions¹⁵.
    Dust Bag Fresh-Air Drying
    Ambient airflow helps dry residual moisture in the dust bag, reducing odors and keeping the dock fresh.
    With its curved surface and fluid silhouette, the dock brings refined style to your home. Behind the elegance lies robust functionality—delivering powerful cleaning support, day after day.
    The dock base stays hygienic with up to 100°C⁴ hot water and the self-cleaning module, reducing manual maintenance.
    55°C Warm Air Drying
    Dries the mops and dock base thoroughly with 55°C¹⁷ of warm air, preventing the growth of mold and unpleasant odors.
    Warm Water Auto-Refilling
    Allows for up to 65 days¹⁸ without manual emptying.
    Detachable Dock Base
    Whole-Home Wellness,
    From Start to Finish.
    Every clean, every cycle—designed for sensitive users and healthier homes. Certified¹⁹ for allergy care, infants, and furry family members.
    Smarter sight, Slimmer Fit
    Smarter sight,
    Slimmer Fit
    Reach Where Others Can’t
    At just 7.98 cm tall, this is one of the slimmest²⁰ Roborock equipped with a full LiDAR system. The retractable LDS allows it to glide effortlessly under low furniture, reaching places other vacuums can’t—and leaving no dust behind.
    100% Success Rate
    Cleaning in Spaces ≥7.98cm High²¹
    Rise, Retract, Navigate Anywhere
    In Open Spaces:
    Under Furniture:
    In Open Spaces:
    Under Furniture:
    Precision Sensors, Reliable Design.
    Upward Range Finder:
    Measures overhead clearance for automatic LDS adjustments.
    Top Contact Sensor:
    Detects overhead obstacles, preventing bumps and scratches.
    Cycle-Tested Durability: LDS mechanism validated through 10,000+ lift-and-retract cycles for long-term reliability.²²
    10,000+
    Cycles
    Knows What’s Ahead
    —And What’s Beside.
    Accurate Object Recognition, Day or Night
    Types of Objects Recognized²³
    VertiBeam Lateral Obstacle Avoidance
    Ensures Accurate Edge Detection
    The VertiBeam lateral laser system precisely measures the distance to side obstacles, enabling accurate edge cleaning along furniture and surrounding objects.
    Tap, Tap, Clean
    • Automatically performs a vacuum-then-mop routine in rooms left uncleaned for over 30 days.
    • Automatically deep cleans rooms that have not been cleaned for a long time
    • Lowers power and reduces noise during Do-Not-Disturb periods
    • Re-washes the mops right after cleaning kitchens and bathrooms or after a second mopping pass
    Roborock SmartPlan 3.0
    One Tap to AI-Driven Cleaning
    From recognizing room types to tracking usage habits, Roborock SmartPlan 3.0 tailors every session—boosting suction when needed, rewashing when it matters. Smarter cleaning, all with just one tap.
    Pet-Friendly Intelligence
    Closer to Your Furry Friends
    Video Call
    Pet Snaps
    Automatic Pet Recognition
    When approaching kittens or puppies, the robot immediately stops its main brush and moves aside to avoid startling your beloved pets.
    Search for the Pet
    Say “Hello Rocky” for Help
    • "Clean here"
    • "Just vacuum"
    • "Clean the kitchen"
    Matter Protocol
    Embrace the Future
    of Smart Living
    Works Great with
    Third-Party Voice Control
    Fully charged
    After Meals
    Launcher Widgets
    Apple Watch App
    Qrevo Curv 2 Pro
    350*352*79.8mm
    450*450*450mm
    11
    *Images and videos are for illustration purposes only and may not exactly represent the product. The app interface is subject to change without notice.
    1.Roborock was the first in the robot vacuum industry to mass produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024. Its threshold-crossing capability is based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
    2.Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
    3.Based on internal testing conducted by the manufacturer. The maximum downward mopping pressure is achieved when the “Deep Cleaning for Heavy Dirt or Stains” function is manually enabled in the Roborock app. Actual results may vary depending on environmental conditions.
    4.Based on testing conducted by TÜV Rheinland. The water at the clean water dispensers of the base can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
    5.This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet cleaning capability was officially introduced in Q3 2025.
    6.Based on Roborock internal testing using Max+ mode. Compared to the performance on the 2cm long-pile carpets of previous Roborock vacuum robots. Actual results may vary according to the home environment.
    7.Based on research conducted by Roborock as of September 2025, the Qrevo Curv 2 Pro delivers the highest suction power among all Roborock robot vacuums.
    8.Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed cf 200 rpm. Actual results may vary depending on environmental factors.
    9.Certified No.PT/25/GEN/0342 by SGS. Actual results may vary according to the home environment.
    10.Certified No.PT/25/GEN/0341 by SGS. Actual results may vary according to the home environment.
    11.Certified No.PT/25/GEN/0340 SGS. Actual results may vary according to the home environment.
    12.Certified No.0217010051 by TÜV Rheinland. Actual coverage and distance may vary depending on the home environment.
    13.Based on testing carried out by TÜV Rheinland on Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000088785. Actual results may vary according to the home environment.
    14.The Soaking Cleaning feature needs to be manually enabled in the Roborock app.
    15.Based on internal testing carried out by the manufacturer. Compared to the results of previous Roborock mop-washing cleaning sessions. Actual results may vary depending on environmental factors.
    16.Compared to the cleaning tray of previous Roborock vacuum robots. Actual results may vary depending on environmental factors.
    17.Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
    18.Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
    19.Based on testing carried out and certified by SGS and TÜV SÜD. Actual results may vary depending on the home environment. Certification ID: No.PT/25/GEN/0370, No.PT/25/GEN/0368, No.Z2GCN1238210008, No.Z2GCN123820009.
    20.Based on research conducted by Roborock, as of September 2025, the Qrevo Curv 2 Pro is the thinnest model among Roborock's vacuum robots.
    21.Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
    22.Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
    23.Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
