    Roborock F25 RT Gen 2
    Smart, Smooth, Stainless
    Buy Now
    Reliably Clean,
    Designed to be Easy
    Outstanding Cleaning Power
    One‑Stroke Deep Clean, Reliably Delivered. Combining 450 RPM3 cleaning frequency and 20,000 Pa suction4 for a thoroughly clean floor—with no effort from you.
    20,000 Pa
    Suction Power4
    20 N
    Downward Cleaning Pressure5
    Bacteria Removal Rate6
    450 RPM
    Cleaning Strokes / min3
    <1 mm Edge-to-Edge Cleaning7
    Enjoy uninterrupted operation. With <1 mm edge cleaning7, a 38-minute8 Eco Mode runtime, and 284 sqm (3,056 sqft)9 of coverage, it cleans every inch of your floor deeply and continuously.
    38-Minute
    Battery Life in Eco Mode8
    Cleaning Area per Charge9
    JawScrapers™ Anti-Tangle Design
    Engineered for Continuous Performance
    Ensure consistently spotless floors with our advanced anti-tangle system—featuring a constant-press scraper that eliminates watermarks and shark-tooth blades that actively trap hair, delivering a smooth, pristine finish with every clean.
    Tangle Rate10
    In Sync with Your Motion
    Optimized Glide Wheels
    Fluid Motion, Engineered In
    Engineered to deliver fluid motion in every move, Optimized Glide Wheels reduce push effort, smooth over floor seams, and clear thresholds effortlessly—transforming cleaning into a seamless, continuous flow.
    Effortless Glide
    Feel the ease in every push.
    Stable Roll
    Safe passage for your home and machine.
    Enhanced Obstacle Clearance
    Glide over thresholds effortlessly.
    70° Swivel Design11
    Stable Base, Agile Moves
    With its low‑center design, it glides steadily and maneuvers effortlessly around furniture, thanks to the responsive 70° swivel steering.
    FlatReach 2.0
    The Uninterrupted Clean
    Clears the way, then reaches in. The 12.5 cm (4.9 in)12 flat design maintains full suction even at 180°, powering under furniture to leave no dust behind.
    Smart-Care Simplicity
    Intelligent Washing,
    Advanced Purification
    90°C/194°F13 high temperature self-washing delivers deep self-cleanliness, followed by advanced solid-liquid-air separation for a thoroughly purified result.
    90°C/194°F
    High Temperature Self-Washing13
    ≥99.99%
    Bacteria Removal Rate14
    Multiple Stages
    Separation System
    Flexible Drying to Fit Your Routine
    Stay fresh and dry with 90°C/194°F15 Hot-Air Self-Drying in an omni-sealed dock.
    Maintenance, Simplified
    Ergonomic Tank Handle
    Effortless, splash-free handling. The contoured grip is designed for comfortable control and secure lifting during tank removal.
    1. Data sourced from SGS and Roborock's internal testing. The hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes under controlled testing conditions. Report number: SHES241002115874. Actual performance may vary depending on environmental conditions.
    2. Based on internal testing carried out by the manufacturer, the stated streak-free refers to residual water streaks of less than 0.2g. Actual results may vary due to usage and environmental conditions.
    3. Based on internal testing carried out by the manufacturer, using MAX mode with a full battery. Actual results may vary due to usage and environmental conditions.
    4. Based on internal testing by the manufacturer with a full battery acceording to IEC 62885-2 standards. Actual results may vary due to usage and environmental conditions.
    6. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default cleaning mode, over 99.99% of bacteria on the floor are effectively removed. Report number: No. Z2GCN 118006 0095 Rev.04. Actual results may vary according to the home environment.
    7. Based on internal testing carried out by the manufacturer. The stated edge-to-edge coverage refers to the left and right sides of the roller. Actual results may vary due to usage and environmental conditions.
    8. Based on internal testing carried out by the manufacturer, using ECO mode with a full battery. Actual results may vary due to usage and environmental conditions.
    9. Based on internal testing carried out by the manufacturer, using ECO mode with a full battery. Actual results may vary due to usage and environmental conditions.
    10. Data sourced from SGS and Roborock's internal testing. The hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes under controlled testing conditions. Report number: SHES241002115874. Actual performance may vary depending on environmental conditions.
    11. Based on internal testing carried out by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each turning at least 35°. Actual results may vary due to usage and environmental conditions.
    12. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
    13. Based on internal testing by the manufacturer. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary due to usage and environmental conditions.
    14. Based on testing carried out by TUV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the roller are effectively removed. Report number: No. Z2GCN 118006 0095 Rev.04. Actual results may vary according to the home environment.
