    Qrevo S Pro
    Buy now
    Multifunctional Dock
    Fresher Mops, Less Hassle.
    Upgraded multifunctional dock with high-temperature cleaning, designed to simplify routine maintenance.
    High-Temperature Mop Self-Cleaning²
    Warm Air Drying
    Auto Tank Refilling
    Detachable Dock Base
    30% Faster Charging³ & Off-Peak Charging
    High Temperature Mop Self-Cleaning²
    High-temperature cleaning helps reduce greasy buildup on mops, ensuring a more hygienic clean in kitchens and dining areas.
    Up to 75°C
    Warm Air Drying
    Warm air drying keeps the mops and dock fresh, prevents odors, and maintains a hygienic environment, so your home stays as clean as it looks.
    45 °C
    Warm Air⁴
    45 dB
    Low Drying Noise⁵
    The dock’s dust bag automatically empties the robot’s dustbin, allowing up to 65 days without manual emptying for long-term convenience.
    65 Days
    Without Manual Emptying⁶
    99.9%
    Pollen Filtration Rate⁷
    Deep Clean, Effortlessly
    18,500 Pa HyperForce Suction¹
    Experience this cleaning powerhouse with 18,500 Pa HyperForce suction¹. Whether on hard floors or carpets, it efficiently lifts deeply embedded dirt and dust, delivering a spotless clean every time.
    HyperForce Suction¹
    Less Tangle. Less Trouble.
    Anti-Tangle Side Brush
    Hair Tangling⁸
    Designed For Easy Maintenance
    All-Rubber Main Brush
    The spiral-designed rubber brush blades transport hair to both ends for easy cleaning. The all-rubber brush also features a floating design that adapts to uneven surfaces for optimal cleaning efficiency.
    Easy-to-Maintain Omni-Wheel
    Mop Like a Pro
    Dual Spinning Mops
    Equipped with dual liftable spinning mops, the robot tackles stubborn stains on hard floors. When it detects carpets, the mops automatically lift to keep them dry, ensuring a seamless clean.
    200 RPM
    Maximum Rotating Speed⁹
    10 mm
    Mop Lifting¹⁰
    30 Levels of
    Water Flow Options
    Powerful cleaning, while you relax.
    Delivers strong cleaning performance at a low noise level, keeping your home clean without disruption.
    < 55 dB
    Mop-only Mode*
    < 60 dB
    Sweep-only Quiet Mode*
    *Based on internal testing carried out by the manufacturer. Actual noise levels may vary due to environmental factors.
    Cleans Where Dust Hides
    With a 9.65 cm slim design¹¹, it easily reaches under sofas, beds, and low cabinets.
    See, Sense, and Steer Clear
    Roborock APP
    The Brain Behind Every Clean
    Powered by intelligence that understands your home, your habits, and even the small details you might miss, turning everyday cleaning into an effortless, thoughtfully smart experience.
    Roborock SmartPlan 2.0
    Roborock SmartPlan 2.0 customizes your cleaning based on your habits, room types, and floor materials for efficient cleaning tailored to your home.
    Carpet Cleaning
    Smart Strategy for Every Carpet*
    Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time.
    Everyday Features
    Temporary Cleaning
    ‘Temp Cleaning’ tackles unexpected spills instantly without interrupting your current schedule, while ‘Temp Skip’ lets you temporarily avoid specific areas as needed.
    Custom Routines
    Customize your cleaning routine in the app by setting the time, cleaning mode, and rooms. The robot then starts cleaning automatically.
    For hard-to-reach areas like under chairs and tables, it can detect and suggest them as ‘No-Go Zones’ to prevent getting stuck.
    Matter Supported¹²
    Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home.
    Your privacy
    our top priority
    Roborock adheres to the strictest global data privacy standards, protecting your personal information at every step.
    error
    Specs
    Roborock Qrevo S Pro
    350 × 353 × 96.5 mm
    340 × 487 × 519 mm
    Product Comparison
    1. Based on internal testing conducted by the manufacturer, the maximum suction power can reach up to 18,500 Pa. Actual results may vary depending on environmental factors. Suction power values may also differ by country or region.
    2. Based on internal testing conducted by the manufacturer. The stated 75 °C refers to the temperature measured at the internal heater output, not the temperature of the mop itself. Actual performance may vary depending on environmental conditions.
    3. Compared to the Roborock Q7 Max. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
    4. Based on internal testing carried out by the manufacturer, the air temperature around the mop can be heated up to 45 °C during drying under 25 °C room temperature. The actual results may vary according to the home environment.
    5. Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45 dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
    6. Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
    7. Certification No.PT/23/GEN/0047/1 by SGS. Actual results may vary depending on usage conditions.
    8. Certified No.PT/24/GEN/0455/3 by SGS. Actual results may vary according to the home environment.
    9. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 RPM.
    10. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10 mm. Actual results may vary depending on environmental factors.
    11. Based on internal testing carried out by the manufacturer.
    12. The Matter protocol will be available through an upcoming OTA. Please stay tuned for the latest updates.
