    Roborock Qrevo 2 Pro
    A Power Leap.
    Everyday Easy.
    A Power Leap. Everyday Easy.
    A Power Leap.
    Everyday Easy.
    Designed for homes with carpets, pet hair, and everyday mess, the Roborock Qrevo 2 Pro brings together powerful suction, zero-tangle brushing, smarter carpet care, and wider edge coverage — all working together to keep your home cleaner with less to manage.
    25,000 Pa HyperForce Suction
    Deep Cleaning in Just One Pass
    Experience true cleaning power with 25,000 Pa HyperForce suction. Whether on hard floors or carpets, it delivers strong pickup for everyday dust, crumbs, and embedded dirt.
    18,500 18,500 18,500Pa
    Max Digital Motor Power¹
    Dual Anti-Tangle System
    Hair In. Tangles Out.
    DuoDivide Main Brush
    Hair Tangling²
    Hair Removal⁵
    Anti-Tangle Side Brush
    Thanks to its innovative arc-shaped asymmetric design, the Anti-Tangle Side Brush uses centrifugal force to guide hair toward the bristle tips, making cleanup quick and easy.
    Hair Tangling²
    See How the Dual Anti-Tangle System Works
    Pick It Up
    Gather It In
    Strip It Off
    The two main brushes feature a 10% speed difference, creating a differential effect that tears apart bundled hair in the central gap for easy removal.
    Suck It In
    Asymmetrical Spiral Arc
    Soft Rubber Baffle
    Longer Side Brush Bristles
    Carpet Cleaning
    No Drips. No Damp Tracks.
    Auto Mop Removal
    When Vacuum-Only
    When Vacuum Carpet First
    Advanced Carpet Cleaning Strategy
    Corner Cleaning
    Reverse the Spin. Cover More.
    All-new Reversible Side Brush
    Compare with Standard
    Side Brush
    Up to
    30% more
    corner coverage³
    Mopping
    Extends and Mops Like a Pro
    FlexiArm Edge Mopping
    1.85mm
    Along the Edge⁷
    Edge Coverage⁸
    Duo Spinning Mops
    15mm
    Mopping Module Lifting⁹
    200RPM
    Maximum Rotating Speed¹⁰
    1.85mm
    Along the Edge⁷
    Edge Coverage⁸
    Duo Spinning Mops
    15mm
    200RPM
    Multifunctional Dock
    A New Look. A Cleaner Routine.
    A Cleaner Mop, Every Time.
    stain removal rate¹¹
    Clean Starts at the Dock
    High-Temperature Mop Self-Cleaning
    Up to 75°C (167°F) high-temperature¹² mop self-cleaning. Helps reduce greasy buildup on mops for a more hygienic clean in kitchens and dining areas.
    Warm Air Drying
    45°C (113°F) warm air drying¹³ with 45dB low drying noise¹⁴. Helps reduce odors and keeps mops and the dock more hygienic between sessions.
    Auto Tank Refilling
    Refills for you, so mopping doesn’t dry out mid-run. No more dragging a dry mop across the floor.
    See, Sense, and Steer Clear.
    Roborock APP
    The Brain Behind Every Clean
    Roborock SmartPlan 3.0
    After room types are selected, Roborock SmartPlan 3.0 learns your cleaning habits and automatically tailors the optimal cleaning strategy for each room, boosting suction where needed, rewashing the mop when necessary, and lowering power to reduce noise during Do-Not-Disturb periods.
    Everyday Features
    Tailored Vacuuming and Mopping Settings
    Fine-tune suction power and water flow in the app for a more customized clean.
    Temporary Cleaning & Skip Cleaning
    Clean on demand or skip zones as needed — perfect for sudden spills or when you need quiet while focusing on work during cleaning.
    Custom Routines
    Come home to clean. Create personalized cleaning schedules so your robot automatically vacuums and mops before you arrive home — keeping your home spotless, right on time, every time.
    Smart Suggestion of No-Go-Zones
    Keep your robot out of trouble. Smart detection identifies tricky areas — like chair legs — and recommends No-Go Zones.
    Target Area Re-Mop*
    Re-mop the spots that need it every time. Mark stubborn areas in the app and the robot will automatically re-mop them during each cleaning run.
    *The feature will be avilable through an upcoming OTA. Please stay tuned for the latest updates.
    Matter Supported
    Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home for seamless smart-home integration.
    Your Privacy,
    Our Top Priority.
    Specs
    352*350*96.6 mm
    402*494*450 mm
    2. Based on internal testing, the hair tangling rate is 0% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending or environmental conditions.
    3. Based on internal testing by the manufacturer. Corner coverage is calculated within a 50 × 50 mm corner area based on the measured distance from the 45° corner point to the brush cleaning arc; uncovered area is defined by the two wall edges and the cleaning arc.
    5. Based on internal testing, the hair removal rate 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all five Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending on environmental conditions.
    9. Based on internal testing carried out by the manufacturer, the mopping modules can be lifted up to 15 mm. Actual results may vary depending on environmerhtal factors.
    12. Based on internal testing conducted by the manufacturer. The stated 75°C refers to the temperature measured at the internal heater output, not the temperature of the mop itself. Actual performance may vary depending on environmental coonditions.
    13. Based on internal testing carried out by the manufacturer the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
