    Roborock Q7 Series
    Roborock Q7 Series
    Everyday Cleaning Made Reliable.
    Roborock Q7 Series
    Roborock Q7 Series
    Up to 13,000 Pa
    HyperForce Suction Power1
    Roborock Q7 Series
    Dual Anti-Tangle System
    Roborock Q7 Series
    Three Levels of
    Water Flow
    Roborock Q7 Series
    PreciSense LiDAR
    Navigation
    Roborock Q7 Series
    Self-Emptying Dock
    Roborock Q7 Series
    Flexible App Control
    Available Options
     Roborock Q7 Pro Max / Q7 TF
     Roborock Q7 Pro Max+ / Q7 TF+
    Impressive HyperForce Suction Power
    Root Out Hair From
    Crevices and Carpets
    Suction Power
    Root Out Hair
    From Crevices and Carpets
    Roborock Q7 Series
    With an impressive suction power, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
    Roborock Q7 Pro Max(+)
    13,000 Pa
    Roborock Q7 TF(+)
    10,000 Pa
    Fewer Tangle. Fewer Trouble.
    Dual Anti-Tangle
    Design
    Roborock Q7 Series
    Roborock Q7 Series
    JawScrapers Comb
    Anti-Tangle Main Brush
    Hair Tangling on Side Brush 2
    Consistent Water Flow Mopping
    Consistent Water
    Flow Mopping
    Removes Dust You
    Hardly See
    Roborock Q7 Series
    3 Levels
    Water Flow Options
    Detachable Mop Design
    For Versatile Cleaning Needs
    Roborock Q7 Series
    Anti Scale Design
    Built-in nonhazardous3 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years4.
    Anti Scale Design Anti Scale Design
    Roborock Q7 Series
    PreciSense LiDAR Navigation
    Learn, Navigate,
    Remember
    Roborock Q7 Series
    Roborock Q7 Series
    RockDock Plus
    Handles Dirty
    Work for You
    Roborock Q7 Series
    Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
    Roborock Q7 Series
    Tap, Tap, Clean
    Roborock Q7 Series
    Roborock Q7 Series
    Temporary Cleaning
    Temporary Cleaning
    Roborock Q7 Series
    Auto Boost on Carpet
    Roborock Q7 Series
    High-Intensity Mopping
    Roborock Q7 Series
    Cleans Along Floor Direction
    Roborock Q7 Series
    Temporary Cleaning
    Temporary Cleaning
    Roborock Q7 Series
    Roborock Q7 Series
    Roborock Q7 Series
    Robot Vacuum
    325 * 325 * 99 mm
    160 * 70 * 101 mm
    Roborock Q7 Pro Max / Q7 TF Dimensions
    Robot Vacuum
    325 * 325 * 99 mm
    212 * 178 * 259 mm
    Roborock Q7 Pro Max+ / Q7 TF+ Dimensions
    • Customizable Cleaning Modes
    • Off-Peak Charging
    • Child Lock
    STAY TUNED IN!
    1. Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. The maximum suction power varies among different models. Actual results may vary depending on usage conditions.
    2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair tangle rate is 0%, while short human hair tangle rate is 0.063% Actual results may vary depending on usage conditions.
