Saros 20 is engineered to master every home environment. The new AdaptiLift Chassis 3.0 conquers 4.5 + 4.3 cm thresholds. With StarSight™ Autonomous System 2.0, it maps faster, positions more precisely, recognizes obstacles with greater accuracy, and also slides into lower spaces. With its triple liftable structure, dual anti-tangle system, and the brand new RockDock, smarter, hands-free cleaning becomes effortless.
An advanced vision system, adaptive algorithms, and a main wheel + auxiliary wheel + climbing arm lifting structure allow the robot to analyze, test, and memorize the best way to cross thresholds—ensuring uninterrupted cleaning across every room.
Equipped with the next-gen StarSight™ Autonomous System 2.0, the Saros 20 achieves a remarkably slim profile, effortlessly navigating under sofas and beds as low as 7.95 cm with advanced localization and mapping capabilities*.
*The body height of the robot vacuum is 7.98 cm. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 7.95 cm. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
*Users should manually mark the location of the curtains on the map through the Roborock app to trigger this function. Actual results may vary depending on environmental factors.
Premium navigation and obstacle avoidance technology ensure precise mapping, superior coverage, and enhanced object recognition—whether it's cables, pets, or unexpected barriers.
VertiBeam Lateral Obstacle Avoidance
Navigation System
Obstacle Recognition
21 x
300+
Types
Precision Edge Cleaning Along Obstacles
Improved Sampling Frequency than LDS⁸
of Recognizable Obstacles⁹
Dynamically adjusts the chassis, main brush, and mop height based on cleaning mode—ensuring optimal contact, coverage, and performance across every surface.
Digital Motor¹⁰
An ultra-powerful digital motor engineered for exceptional cleaning performance.
Hair Tangling Rate¹³
Hair Tangling Rate¹¹
Hair Removal Rate¹²
No more brush maintenance with the new anti-tangle system on the main brush and side brush that expertly handles long hair and is optimized for pet-friendly environments.
When tough stains are detected, the robot automatically increases downward pressure by lifting its Omni-Wheels to press the upgraded mops harder for deeper scrubbing, better stain removal, and improved water-mark cleaning.
Downward Pressure¹⁵
Downward Pressure¹⁶
Edge and Corner Coverage¹⁷
Along the Edge and Corner¹⁸
100℃ Hot Water Mop Washing
100℃ Hot Water Dock Self-Cleaning
Dust Bag
Fresh-Air Drying
Auto Mop
Removal
Smart Re-Wash
& Re-Mop
55℃ Warm
Air Drying
Warm Water Tank Refilling
Auto Dust
Emptying
Auto Detergent Dispenser
2.5-Hour Fast Charge
Hot-Water Mop Washing¹⁹
Hot-Water Mop
Washing¹⁹
Bacteria Removal Rate²⁰
Bacteria Removal
Rate²⁰
Less Maintenance Needed For the Cleaning Tray²²
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time²⁷.
Roborock SmartPlan 3.0
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Track Your Pet
Video Call & Cruise
Everyday Features
Key Specs
Saros 20
Saros 20
353 x 350 x 79.8 mm
381 x 475 x 488 mm
Weight
Saros 20
5.05 kg
10.54 kg
1. Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 4.5 cm, the gap depth between the two thresholds is greater than 12 cm and does not exceed 14 cm, and the second threshold height does not exceed 4.3 cm, the robot is capable of crossing double-layer thresholds with a combined height of up to 8.8 cm. Actual performance may vary depending on environmental conditions and actual user usage.
2. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
3. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
4. Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 4.5 cm, the gap depth between the two thresholds is greater than 12 cm and does not exceed 14 cm, and the second threshold height does not exceed 4.3 cm, the robot is capable of crossing double-layer thresholds with a combined height of up to 8.8 cm. Actual performance may vary depending on environmental conditions and actual user usage.
5. Based on Roborock’s internal R&D records and available public information, this feature is powered by Roborock’s AdaptiLift Chassis 3.0—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet cleaning capability was officially introduced in Q3 2025.
6. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
8. Based on internal testing by the manufacturer according to the LDS sampling frequency calculation method.
9. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 2cm wide and 2cm tall. Recognition accuracy may vary depending on environmental factors.
10. Based on internal testing of the digital motor under specific conditions. Actual results may vary depending on product configuration and usage conditions.
11. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
12. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
13. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
14. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
16. Based on internal testing by the manufacturer. The maximum downward mopping pressure is achieved when the “Deep Cleaning for Heavy Dirt or Stains” function is manually enabled in the Roborock app. Actual performance may vary depending on environmental conditions.
17. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
18. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
19. Based on internal testing by the manufacturer. The water at the clean water dispensers of the base can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
20. Based on testing carried out by TÜV Rheinland under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Actual results may vary according to the home environment.
21. Based on internal testing carried out by the manufacturer. Compared to the results of previous Roborock mop-washing cleaning sessions. Actual results may vary depending on environmental factors.
22. Compared to the cleaning tray of previous Roborock robot vacuums. Actual results may vary depending on environmental factors.
23. Based on testing conducted by TÜV Rheinland. The water at the clean water dispensers of the base can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
24. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
26. Based on internal testing carried out by the manufacturer and compared to the previous Roborock robot vacuums. Actual results may vary depending on environmental factors.
27. This feature is applicable to household carpets with pile heights of 3 cm or below, which covers the majority of carpets used in typical homes.
