    Saros 20 Neo
    More Coverage, Always Ready.
    Saros 20 Neo
    Designed for complex homes, it delivers powerful vacuuming and deep mopping—while climbing thresholds, gliding under furniture, and adapting across carpets. Saros 20 Neo knows where to go, what to avoid, and finishes the job on its own.
    Expanded Cleaning Reach
    Climbs over high thresholds and slides under furniture with ease.
    Powerful Suction & Tangle-Free Cleaning
    Picks up dust and hair while helping prevent tangles.
    Enhanced Mopping Performance
    Delivers warm-water mopping with minimal water residue.
    Advanced Carpet Cleaning
    Built for Better Carpet Care
    Intelligent Obstacle Handling
    Sees more. Reacts smarter. Cleans better.
    Hygienic Multifunctional Dock
    100°C¹ Hot Water Mop Washing and Auto Detergent Dispenser for a deeper clean.
    Clean More of Your Home,
    Effortlessly.
    AdaptiLift Chassis 3.0
    Climbs Higher. Goes Further.
    Powered by AdaptiLift Chassis 3.0 with a climbing arm, it lifts and climbs over high thresholds effortlessly—so cleaning doesn’t stop at boundaries.
    4.5 cm + 4.3 cm
    20,000 +
    Threshold Crossings Tested³
    Sees Clearly, Even in Low Spaces
    7.95 cm
    Low-Clearance Access⁴
    100,000+
    Lift Cycles Tested⁵
    Across Every Surface,
    Into Every Corner.
    36,000 Pa HyperForce Motor
    Deep Cleaning, Made Effortless.
    An ultra-powerful motor delivers consistent suction to lift dust, debris, and hair across every surface.
    36,000 Pa
    Max Digital Motor Power⁶
    Dual Anti-Tangle System
    No Tangles.
    No Interruptions.
    Designed to handle even long hair, the DuoDivide Main Brush and FlexiArm Arc Side Brush work together to prevent tangles and maintain continuous cleaning.
    Hair Tangling Rate⁷
    Hair Removal Rate⁸
    Hair Tangling Rate⁹
    Deeper Mopping. Less Residue.
    30%
    Less Water Residue¹⁰
    14N
    200 RPM
    Spinning Speed¹²
    Industry-First Dynamic Cleaning for Up to 3 cm Carpets
    Automatically adjusts its chassis to maintain strong suction on carpets up to 3 cm¹³—delivering deeper, more consistent cleaning*.
    Automatic Mop Detachment
    Automatically detaches the mop in Vacuum Carpet First Mode*—keeping carpets dry and protected.
    When Deep Carpet Cleaning Mode* is enabled, the main brush stays in a stable downward position on a second pass—improving debris pickup compared to its usual floating state.
    prev prev hover
    next next hover
    FlexiArm Technology
    Reaches Edges. Cleans Corners.
    Roborock’s FlexiArm Arc Side Brush and Edge Mopping System clean tightly along walls and into corners, while the extendable side brush reaches under toe-kick areas for more complete coverage.
    Edge Mopping System
    Edge and Corner Coverage¹⁴
    0mm
    Along the Edge and Corner¹⁵
    Liftable Brush and Mops
    Vacuum Only
    Mop Mode
    Clean Carpet
    checked Mops detached
    checked Main brush lowered
    checked Main brush lifted
    Handles Obstacles—
    So You Don’t Have To.
    Advanced Obstacle Avoidance
    Powered by Reactive AI Obstacle Recognition, which combines structured light and an RGB camera, together with VertiBeam Lateral Obstacle Avoidance, it detects more obstacles near and far—even along walls and furniture—with minimal blind spots.
    TUV Certified
    More Objects Recognized
    200 +
    Saros 10 Series¹⁶
    300 +
    Saros 20 Neo¹⁷
    Cleans Behind Curtains
    With manual curtain marking in the app, it cleans behind curtains and soft partitions—covering hidden areas without the need to lift or adjust them.
    Cleans What Gets Missed
    If cleaning is temporarily blocked by people or pets, it continues elsewhere—and automatically returns to clean missed spots once the path is clear*.
    Won’t Push Through Closed Doors
    When doors are closed, it moves on instead of pushing or bumping—helping protect your doors while keeping cleaning smooth and uninterrupted.
    Gets Itself Unstuck
    Recognizes obstacles like chair legs, then intelligently adjusts its movement—using its liftable chassis and climbing arms to free itself and keep cleaning moving.
    prev prev hover
    next next hover
    It Cleans.
    Then It Cleans Itself.
    Brand New Multifunctional Dock
    100°C Hot-Water Mop Washing
    Uses up to 100°C hot water to loosen grease and stubborn residue for a more hygienic clean.
    TUV Certified
    Up to
    100℃
    Hot-Water Mop Washing¹
    Bacteria Removal Rate¹⁸
    Smart Mop-Washing Mode
    Equipped with an auto detergent dispenser, the dock automatically adds cleaning solution for a more thorough and effortless mop cleaning
    The dock base stays hygienic with up to 100°C¹ hot water and the self-cleaning module, reducing manual maintenance.
    55°C Warm Air Drying
    Dries the mops and dock base thoroughly with 55°C¹⁹ of warm air, preventing the growth of mold and unpleasant odors.
    Warm Water Auto-Refilling
    Allows for up to 65 days²⁰ without manual emptying.
    Detachable Dock Base
    Roborock APP
    The Brain Behind Every Clean
    Carpet Cleaning
    Roborock SmartPlan 3.0
    Pet-Friendly Intelligence
    Closer to Your Furry Friends
    Automatic Pet Recognition
    Pet Snaps
    Search for the Pet
    Video Call & Cruise
    Pet Snaps
    Search for the Pet
    Video Call & Cruise
    Everyday Features
    Stain-Target AI Cleaning
    Built-in Voice Assistant
    Third-Party Control
    Pet Care Hub
    Designed for homes with pets, it brings cleaning settings, pet zones, and even pet albums together in one dedicated space within the app.
    Key Specs
    Saros 20 Neo
    Saros 20 Neo
    Saros 20 Neo
    352 x 350 x 79,8 mm
    402 x 494 x 450 mm
    * Images and videos are for illustration purposes only and may not exactly represent the product. The app interface, feature availability, and navigation paths are subject to change without notice.
    1. Based on internal testing conducted by the manufacturer. The heating module can heat water up to 100°C under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual results may vary depending on usage and environmental conditions.
    4. The body height of the robot vacuum is 7.98 cm. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 7.95 cm. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
    7. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
    8. Based on internal testing, the hair removal rate reached 100% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) under controlled test conditions. Actual results may vary depending on environmental conditions.
    9. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
    13. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors. This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet-cleaning capability was officially introduced in Q3 2025.
    16. Compared with the Roborock Saros 10 and Roborock Saros 10R under internal test conditions. Recognition accuracy may vary depending on environmental factors.
    19. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
    21. These carpet cleaning settings must be manually enabled and selected in the Roborock app. This feature is applicable to household carpets with pile heights of 3 cm or below, which covers the majority of carpets used in typical homes.
