    Roborock QR 798
    Multifunctional Dock
    Hands-Off, Hassle-Free
    Mop Self-Washing
    Self-Drying
    Auto Tank Refilling
    Detachable Dock Base
    Off-Peak Charging
    Mop Self-Washing
    3-Stage
    Dynamic Cleaning Process
    Self-Drying
    Room-temperature air drying keeps both the mops and dock fresh, preventing odors and maintaining a hygienic environment, so your home stays as clean as it looks.
    45dB
    Low Drying Noise3
    The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience. 4
    65 days
    without Manual Emptying5
    99.90%
    Pollen Filtration Rate6
    10000Pa HyperForce® Suction1
    Deep Clean, Effortlessly
    HyperForce® Suction
    Experience this veritable cleaning powerhouse with its 10000Pa HyperForce® suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
    Less Tangle. Less Trouble.
    Anti-Tangle Side Brush
    Hair Tangling7
    All-Rubber Main Brush
    Dual Spinning Mops
    Mop Like a Pro
    200RPM
    Maximum Rotating Speed8
    10mm
    Mop Lifting9
    30 Levels of
    Water Flow Options
    See, Sense, and Steer Clear
    Smarter Than You'd Imagine
    PreciSense LiDAR Navigation
    Scans quickly to know your home environment and creates detailed maps to find an optimal route to clean your home.
    6x Faster
    Quick Mapping10
    3D
    Map Display
    Multi-level
    Mapping System
    Tap. Tap. Clean2
    roborock app tap tap clean easy to use
    Roborock SmartPlan
    Powered by AI, the Roborock SmartPlan is a game-changer. With just a tap on the App, you can relax and let the robot take over. Based on the analyzed environment, it will automatically determine the optimal cleaning sequence and method.
    Temporary Cleaning
    Custom Routines
    Broadly Compatible with
    Third-Party Voice
    Control Supported
    Fully charged
    After Meals
    Launcher Widgets
    Apple Watch
    Roborock QR 798
    350*353*96.5mm
    340*487*519mm
    STAY TUNED IN!
    1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 10,000 Pa. Actual results may vary due to environmental factors. Suction power values may vary by country or region.
    3. Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
    4. Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
    5. Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
    6. Certification No.PT/23/GEN/0046 by SGS (product code name:RRW0PEP). Actual results may vary depending on usage conditions.
    7. Certified No.PT/24/GEN/0454/1 by SGS (product code name:RRW0PEP). Actual results may vary according to the home environment.
    8. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200RPM.
    9. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm. Actual results may vary depending on environmental factors.
