    Roborock Qrevo C Pro
    Meet your new cleaning powerhouse - the Roborock Qrevo C Pro. Designed to blend seamlessly into your daily routine, it boasts the Dual Anti-tangle system and impressive 18,500 Pa suction1, making hair tangles a thing of the past. Paired with the Multifunctional Dock, obstacle avoidance system and convenient App Control, keeping your home tidy is a breeze.
    Zero Wraps. Double Guard.3,5
    DuoDivide Main Brush
    Hair tangles? No worries. Equipped with two parallel short bristle rollers and spiral blades, the DuoDivide Brush works in harmony to deftly direct hair toward the central dustbin inlet. It prevents tangles and clogging, ensuring that your floors are left impeccably clean without hair.
    Hair Tangling3
    Hair Removal4 This is a image
    Anti-Tangle Side Brush
    Hair Tangling5
    18,500Pa HyperForce Suction1
    Deep Clean, Effortlessly
    HyperForce Suction
    Experience this veritable cleaning powerhouse with its 18,500Pa HyperForce Suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
    FlexiArm Edge Mopping
    Extend, Mop, and Conquer
    1.85mm
    Along the Edge6
    98.80%
    Edge Coverage6
    Dual Spinning Mops
    Mop Like a Pro
    200RPM
    Maximum Rotating Speed7
    10mm
    Mop Lifting8
    30 Levels of
    Water Flow Options
    See, Sense, and Steer Clear
    Hands-Off, Hassle-Free
    Effortlessly lift oil stains from mops with 75°C hot water9, ideal for kitchen and dining areas, while also saving time and water. The hot water effectively removes over 99.99% of bacteria on the spinning mops10.
    75°C Hot Water Mop Self-Washing9
    Warm Air Drying
    Auto Tank Refilling
    Detachable Dock Base
    30% Faster Charging11 &
    Off-Peak Charging
    Hot Water Mop Washing
    75°C
    Hot Water Washing9
    75°C hot water effectively removes stubborn stains and other dirt, saving time and water, while also disinfecting, to ensure that the mops are clean for an improved mopping experience9.
    Warm Air Drying
    45°C
    Warm Air12
    45dB
    Low Drying Noise13
    The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience.14
    65 days
    without Manual Emptying15
    99.90%
    Pollen Filtration Rate16
    Tap. Tap. Clean2
    Roborock SmartPlan
    Powered by AI, the Roborock SmartPlan is a game-changer. With just a tap on the App, you can relax and let the robot take over. Based on the analyzed environment, it will automatically determine the optimal cleaning sequence and method.
    Temporary Cleaning
    Custom Routines
    Broadly Compatible with
    Third-Party Voice
    Control Supported
    Fully charged
    After Meals
    Launcher Widgets
    Apple Watch
    350*353*96.5mm
    340*487*519mm
    2. Software user interface and functionalities may vary with software version updates. Actual software features and user interface are subject to the latest software version.
    9. Based on internal testing carried out by the manufacturer. The water temperature at the hot water outlet of the dock can reach up to 75°C. Actual results may vary depending on usage conditions such as environmental temperature.
    10.Based on testing carried out by TUV Rheinland. Effectively removes 99.99% of Staphylococcus aureus and Escherichia coli from the mop after self-cleaning. Certification ID: 0000088666. Actual results may vary depending on usage conditions.
    11.Compared to the Roborock Q7 Max. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
    12.Based on internal testing carried out by the manufacturer, the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
    13.Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
    14.Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
    15.Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
    16.Certification No.PT/23/GEN/0046 by SGS (product code name:RRW0PEP). Actual results may vary depending on usage conditions.
