    Roborock F25 Series
    Roborock F25 Series
    Smart, Smooth, Stainless
    Roborock F25 Series
    Smart Wet-and-Dry Cleaning
    Spotless with a Single Stroke
    JawScrapers™
    Complete Clean
    Stays Clean and Ready to Roll
    Seamless and Upgraded
    Maneuverability
    Intelligent App and
    Voice Alerts
    Sticky, Even Hairy Mess?
    Make It No Mess.
    99.99 %2
    Bacteria Removal Rate
    99.99 %2
    Spend less time cleaning and more time living. With 20,0001 Pa suction and a 450 RPM cleaning frequency, the Roborock F25 Series delivers spotless results in a single stroke.
    Cleaning Strokes3 / min
    20,000 Pa5
    Suction Power
    >20 N4
    Downward Cleaning Pressure
    <1mm
    Edge-to-Edge Cleaning9
    <1mm
    60 min7
    Battery Life under Eco Mode
    410 sqm8(4,413 sqft)
    Cleaning Area per Charge
    JawScrapers™ Roller
    Designed for Lasting Shine
    Tangle Rate10
    FlatReach 2.0
    12.5cm 0°
    DirTect Smart Sensor
    Smarter for Superior Cleaning
    Cleaning Level
    4 ...
    Dirt Level
    Auto Detergent Dispenser
    *Available on Roborock F25 ALT and Roborock F25 ACE.
    Proactive Self-Washing
    As you clean, the F25 series uses the DirTect module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
    Moves as You Move
    Small Tweak, Big Improvement
    90 °C13
    5 min
    Fast Drying
    99.99 %14
    Multiple Stages
    Separation System
    99.99 %14
    Multiple Stages
    Separation System
    Intuitive to Use,
    Voice Alert
    Auto
    Cleaning Rollers
    Empty the dirty water tank
    Auto
    Cleaning Rollers
    One-Touch App Customization*
    0 0
    13.Based on internal testing. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary depending on environmental factors.
