    Flex Your Clean
    Buy Now
    Introducing Roborock Flexi - the ultimate flexible solution for all your cleaning needs. Leveraging Roborock's vast expertise in home cleaning, it excels in handling wet and dry messes, delivering edge-to-edge cleaning performance, and effortlessly navigating beneath low-profile furniture. Enhanced with smart features like adaptive cleaning and self-cleaning, plus app compatibility, it offers effortless and worry-free operation.
    Edge-to-Edge Cleaning: No Corner Left Untouched
    Reaches Everywhere, Even Under Low Furniture
    DirTect: Automatically Adapts Cleaning and Self-Cleaning
    Intelligent App and Voice Alerts for a Convenient Clean
    One-Stroke Wet & Dry Cleaning
    Cleaning should be efficient, so your precious time is spent on more important matters. From cooking mess to your little ones’ playful chaos, Roborock Flexi has it all covered with a single stroke. With 17,000 Pa1 suction power, it’s ensured to meet your high standards of home cleanliness and tidiness.
    With DirTect adaptive cleaning capability, Roborock Flexi adjusts its cleaning power according to dirt levels on the floor, ensuring a thorough and time-saving cleaning experience. When self-cleaning at the base, DirTect checks if your roller has been cleaned effectively and switches to Deep Clean mode if it detects that the roller is still dirty after washing.
    Always Clean, Always Fresh
    Incorporating Roborock’s automatic self-drying & cleaning technology for wet-dry vacuums, Roborock Flexi self-cleans with a roller scrape and water spray module, ensuring a sparkling clean result while cleaning your floor.
    55℃
    60℃
    Hot Water Self-cleaning
    30 min
    Auto Brush-Drying
    99.9%4
    Bacteria Removal Rate
    With Roborock Flexi’s hot water self-cleaning and hot air self-drying feature, the roller is being scraped and washed in two directions with 60℃2 (140℉) hot water, complemented by the flow of 55℃3 (131℉) heated air, guaranteeing a hygiene and odor-free experience in 30 min.
    15 cm5
    Flexibility is the Key
    Roborock Flexi features FlatReach technology for thorough cleaning under low furniture.
    Roborock Flexi easily reaches edges and corners with side margins of less than 1 mm6.
    All in Reach, All in Sound
    With an LED screen accessible at your fingertips, monitoring modes and status becomes effortless. Roborock Flexi also provides real-time updates and operational reminders through convenient voice alerts.
    Auto
    Cleaning rollers
    Empty the dirty water tank
    Effortless Clean, Now Elevated with Intelligence
    Room
    Temperature
    Warm
    Hot
    Maintenance
    50%
    75%
    Start Time
    16: 47
    Repeat
    Weekdays
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    00
    10
    20
    30
    40
    50
    Your Cleaning, Your Way
    The Roborock App tailors the cleaning experience to your precise requirements. Unlock a range of intelligent features for customization, including a self-drying and cleaning timer, water temperature adjustment, suction power control, and more.
    Long-Lasting Cleanups
    With a substantial 50 min battery life, it delivers prolonged cleaning sessions without interruption, enabling an extensive cleaning coverage (420 sqm/ 4520 sqft7) before requiring recharging.
    730 ml
    Clean Tank size
    50 min8
    Battery Life
    450 ml
    Dirty Tank Size
    Cleaning That Lasts
    Roborock Flexi Pro Roborock Flexi Roborock Flexi Lite
    Flexi-Pro Flexi Flexi-Lite
    Up to 50 min Battery Life
    Up to 40 min Battery Life
    30 min Auto Brush-Drying
    60 min Auto Brush-Drying
    5 kg Weight
    4.7 kg Weight
    4 kg Weight
    730 ml Clean Water Tank Size
    620 ml Clean Water Tank Size
    450 ml Dirty Tank Size
    400 ml Dirty Tank Size
    Double Edges Cleaning Design
    Single Side Edge Cleaning
    Hot Air Self-Drying
    Hot Air Self-Drying
    Hot Air Self-Drying
    Hot Water Self-Washing
    Standard Self-Washing
    SlideTech Adaptive Wheels
    Built-in Headlight
    App Compatibility
    App Compatibility
    Flexi-Pro
    Roborock Flexi Pro
    Flexi
    Roborock Flexi
    Flexi-Lite
    Roborock Flexi Lite
    5 kg Weight
    Hot Air Self-Drying
    Built-in Headlight
    App Compatibility
    4.7 kg Weight
    Hot Air Self-Drying
    App Compatibility
    4 kg Weight
    Hot Air Self-Drying
    2. Based on internal testing, the water in the clean water tank can be heated up to 60℃ at standard room temperature. The actual temperature will vary due to environmental factors.
    3. Based on internal testing, the water in the clean water tank can be heated up to 55℃ at standard room temperature. The actual temperature will vary due to environmental factors.
    4. Based on testing carried out by TUV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.9% of bacteria on the roller are effectively removed. Test Report number: 244555550b3 001. Actual results may vary according to the home environment.
    6. Based on internal testing. Actual results may vary depending on environmental factors.
    7. Based on internal testing carried out by the manufacturer under ECO mode.
    8. Based on internal testing carried out by the manufacturer under ECO mode.
