    Flex Your Clean
    Buy Now
    FlatReach Technology: Reaches Every Nook, Even Under Low Furniture
    DirTect: Automatically Adapts Cleaning and Self-Cleaning Performance
    One-Stroke Wet & Dry Cleaning
    With DirTect adaptive cleaning capability, Roborock Flexi Lite adjusts its cleaning power according to dirt levels on the floor, ensuring a thorough and time-saving cleaning experience. When cleaned at the base, DirTect checks if your roller has been cleaned effectively and switches to Deep Clean mode if it detects that the roller is still dirty after washing.
    Always Fresh, Always Clean
    Incorporating Roborock’s automatic self-drying & cleaning technology for wet-dry vacuums, Roborock Flexi Lite self-cleans with a roller scrape and water spray module, ensuring a sparkling clean result while cleaning your floor.
    122°F
    60
    min
    Auto Brush-Drying
    60 min
    50°C/122°F
    Auto Brush-Drying
    Hot Air
    With Roborock Flexi Lite’s hot air self-drying feature, the roller is being scraped and washed in two directions with water, complemented by the flow of 50℃ (122℉) heated air, guaranteeing a hygiene and odor-free experience in an hour.
    6inch3
    Flexibility is the Key
    Roborock Flexi Lite features FlatReach technology for thorough cleaning under low furniture, leaving no place for dirt to hide, ensuring a spotless clean.
    Edge Cleaning
    Roborock Flexi Lite easily reaches edges and corners with side margin of less than 1mm (1/8inch)4.
    All in Reach, All in Sound
    Auto
    Cleaning rollers
    Empty the dirty water tank
    Lightweight Design
    Weighing only 4kg (8.8lbs), Roborock Flexi Lite makes it easy to clean up messes without lugging around a heavy vacuum cleaner from room to room.
    4kg
    Cleaning That Lasts
    Long-Lasting Cleanups
    620ml
    Clean Tank size
    40min
    Battery Life
    400ml
    Dirty Tank Size
    STAY TUNED!
    Roborock Flexi Lite Roborock Flexi Pro Roborock Flexi
    Flexi-Lite Flexi-Pro Flexi
    Up to 40 min Battery Life
    Up to 50 min Battery Life
    60 min Auto Brush-Drying
    30 min Auto Brush-Drying
    4 kg Weight
    5 kg Weight
    4.7 kg Weight
    620 ml Clean Water Tank Size
    730 ml Clean Water Tank Size
    400 ml Dirty Tank Size
    450 ml Dirty Tank Size
    Single Side Edge Cleaning
    Double Edges Cleaning Design
    Hot Air Self-Drying
    Hot Air Self-Drying
    Hot Air Self-Drying
    Standard Self-Washing
    Hot Water Self-Washing
    SlideTech Adaptive Wheels
    Built-in Headlight
    App Compatibility
    App Compatibility
    Flexi-Lite
    Roborock Flexi Lite
    Flexi-Pro
    Roborock Flexi Pro
    Flexi
    Roborock Flexi
    4 kg Weight
    Hot Air Self-Drying
    5 kg Weight
    Hot Air Self-Drying
    Built-in Headlight
    App Compatibility
    4.7 kg Weight
    Hot Air Self-Drying
    App Compatibility
