Roborock H60 - Bend to Reach, Power to Clean | Roborock the United Arab Emirates
    Maximize Efficiency,
    Master Every Clean.
    Advanced Hygiene and Self-Maintenance for Lasting Performance
    Enhanced for Comfort, Engineered for Convenience
    Roborock H60
    Buy now
    Experience a smarter way to clean with the Roborock H60 Series. Designed for effortless deep cleaning, it features a flexible wand to reach tricky spots, powerful suction to tackle dirt with ease, and a long-lasting battery for uninterrupted cleaning. The green light illumination uncovers hidden dust for a more thorough clean, while the advanced filtration system helps keep your home’s air fresh by reducing secondary pollution.
    Up to 115AW Suction
    Unleash True Suction Power
    Powered by a powerful 115AW maximum suction, the Roborock H60 swiftly removes dirt, dust, and debris from carpets and hard floors. TÜV Rheinland-certified³, its performance delivers a deep, meticulous clean every time.
    Up to
    115 AW³
    Whole-Machine Suction Power
    Keep Going, Keep Cleaning
    Enjoy uninterrupted cleaning with up to 60 minutes of runtime on a single charge. Need more time? The detachable battery lets you swap in a fresh one for extended cleaning sessions.
    *Extra battery sold separately.
    Up to
    60 -Min⁴
    Battery Life
    Flexible and Bendable Wand
    Bend, Flex, Clean
    The flexible wand bends up to 90°, effortlessly gliding under furniture to clean tight spaces as narrow as 5.6cm, ensuring a thorough and hassle-free clean.
    Down to
    5.6 cm⁵
    Low Reach
    0°
    Anti-Tangle Brush for Floors and Carpets
    Flawless Cleaning Across Surfaces
    JawScrapers™ Hybrid Brush
    The curved shark-tooth design and the integrated fiber-rubber roller work together to capture, guide, and separate hair during cleaning—minimizing tangles and making maintenance easier.
    0%⁶
    Tangle Rate
    Effortless Floor & Carpet Cleaning
    A perfect combination of rubber strips and soft fibers works wonders on both carpets and hard floors. The rubber strips shake loose embedded dirt with 7,200 beats per minute, while the soft fibers sweep up fine dust and debris.
    7200 beats/min⁷
    Patting frequency
    Green Light Illumination
    Illuminate Dust, Elevate Cleaning
    A precision-engineered green light with a 140° wide-angle uncovers hidden dust and fine particles, ensuring a more thorough and effortless clean.
    5-Stage Filtration System
    Beyond Clean, Breathe Clean
    The Roborock H60 Series features a 5-stage filtration system that captures up to 99.95% of microdust particles as small as 0.3 microns, releasing cleaner air into your home.
    Up to
    99.95%⁸
    retention of microdust particles
    Cyclone Filtration
    Metal Mesh
    Multi-Cyclone Component
    Sponge Filter
    5
    H13 HEPA Filter
    Allergy-Friendly
    Cleaning You Can Trust
    Engineered to support a healthier home environment, our advanced filtration and cleaning system is tested and certified to effectively remove common allergens from floors and indoor air*—delivering measurable relief.
    *Tested by SGS. Results show >99.9% removal efficiency for pollen (floors only) and >99.9% removal and filtration efficiency for cat and dog dander. Actual results may vary depending on usage conditions.
    9-Cyclone Dust Separation System
    Ensures Continuous Power
    The advanced 9-cyclone system efficiently separates dust and debris, minimizing filter clogging and ensuring powerful, consistent suction every time.⁹
    The spiral metal mesh filter in the dust bin channels hair and dust into the bin smoothly, reducing tangles in the mesh and maintaining steady suction for efficient cleaning.
    Multiple Tools and Accessories
    2-in-1 Crevice Brush
    The 2-in-1 crevice brush helps clean tight spaces and delicate surfaces with ease.
    Washable Dustbin and HEPA Filters
    The washable dustbin and filters make cleaning easy and help keep the vacuum running efficiently over time.¹⁰
    Roborock H60
    Vacuum
    293*250*1162mm
    STAY TUNED IN!
    1. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN253JHD001.
    2. For use within a home environment only. Actual results may vary depending on usage conditions.
    3. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25LG2F001.
    4. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
    5. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
    6. Certified NO.PT/25/GEN/0216/1 by SGS. Actual results may vary according to the home environment.
    8. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25LG2F001.
    9. Certified NO.PT/25/GEN/0215 by SGS. Actual results may vary according to the home environment.
    10. Actual results may vary depending on usage conditions.
