    Q5 Pro Series
    Series
    Clean with Double Simplicity.
    Experience a revolution in cleaning with the DuoRoller Brush. Coupled with an impressive 5,500 Pa suction and smart navigation, the Q5 Pro delivers an effortless cleaning experience.
    2x
    All-Rubber Brushes
    20%↑
    Hair Pick-up Rate1
    Double Rollers for
    Double the Power
    Introducing the DuoRoller Brush, the latest in Roborock's cleaning technology, designed to enhance vacuuming performance on carpets and ensure fewer hair tangles to provide a hassle-free cleaning.
    2x
    All-Rubber Brushes
    20%↑
    Hair Pick-up Rate1
    Impressive 5,500 Pa
    Suction Power
    HyperForce suction power has been upgraded to 5,500 Pa2, allowing Q5 Pro to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
    Seamless Floor Cleaning
    Larger Dustbin for
    Longer Pet Hair
    Clean On and On
    240 min
    Maximum Runtime3
    350 sqm (3767 sqft)
    Maximum Vacuuming Area3
    Remove Dust You Hardly See
    Detachable Design
    for Versatile Cleaning Needs
    Clean As You Wish
    Custom Cleaning Routine
    Fast Cleaning
    Speak to Command
    Handles Your Dirty Work
    7 Weeks
    *RockDock Plus is only available with the Roborock Q5 Pro+.
    • Customizable App Features
    • Sensient Sensor Array
    • Adaptive Route Algorithms
    • Child Lock
    • Off-Peak Charging
    Q5 Pro Dimensions
    Robot vacuum
    350*353*96.5 mm
    305*440*448 mm
