    Q8 Max +
    Series
    Join the cleaning revolution and experience effortless cleanups with the all-new DuoRoller Brush. Achieve total dirt and dust removal with the impressive 5,500 Pa suction and smart navigation powered by the Reactive Tech obstacle avoidance system. Cleaning has never been easier.
    2x
    All-Rubber Brushes
    20%↑
    Hair Pick-up Rate1
    Double Rollers for
    Double the Power
    Introducing the DuoRoller Brush, the latest in Roborock’s cleaning technology, designed to enhance vacuuming performance on carpets, ensuring fewer hair tangles, and providing a hassle-free cleaning experience.
    2x
    All-Rubber Brushes
    20%↑
    Hair Pick-up Rate1
    Impressive 5,500 Pa
    Suction Power
    HyperForce suction power has been upgraded to 5,500 Pa2, allowing Q8 Max to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
    Seamless Floor Cleaning
    Remove Dust You Hardly See
    30 Levels
    Water Flow Options
    Detachable Design
    for Versatile Cleaning Needs
    PreciSense LiDAR Navigation creates detailed and accurate maps, enabling the Q8 Max to identify the most efficient route to navigate and optimally clean your home.
    • 6x Faster
      Quick Mapping3
    • 3D
      Map Display
    • Multi-level
      Mapping System4
    Clean As You Wish
    Custom Cleaning Routine
    Fast Cleaning
    Clean On and On
    240 min
    Maximum Runtime6
    300 sqm (3230 sqft)
    Maximum Vacuuming Area6
    Speak to Command
    Handles Your
    Dirty Work
    7 Weeks
    *RockDock Plus is only available with the Roborock Q8 Max+.
    • Customizable App Features
    • Sensient Sensor Array
    • Adaptive Route Algorithms
    • Child Lock
    • Off-Peak Charging
    Q8 Max Dimensions
    Robot vacuum
    350*353*96.5 mm
    305*440*448 mm
