Hair tangles? No worries. Equipped with two parallel short bristle rollers and spiral blades, the DuoDivide™ Brush works in harmony to deftly direct hair toward the central dustbin inlet. It prevents tangles and clogging, ensuring that your floors are left impeccably clean without hair.
Hair Tangling3100%
Hair Removal4
Hair Tangling5
HyperForce® SuctionExperience this veritable cleaning powerhouse with its 12000Pa HyperForce® suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
1.85mm
Along the Edge698.80%
Edge Coverage6
200RPM
Maximum Rotating Speed7
10mm
Mop Lifting8
30 Levels of
Water Flow OptionsEquipped with dual liftable spinning mops, the robot tackles stubborn stains on hard floors. Plus, when it detects carpets, the mops automatically lift to keep them dry, ensuring a seamless clean.
3-Stage
Dynamic Cleaning ProcessDrawing inspiration from the cleaning process of a washing machine, the Multifunctional Dock offers a comprehensive mop-washing experience. It includes a slow pre-wash, a medium rinse, and high-speed spin-drying. What's more, it dynamically adjusts the speed and water flow for maximum efficiency and convenience.
45°C
Warm Air1045dB
Low Drying Noise11The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience.12
65 days
without Manual Emptying1399.90%
Pollen Filtration Rate14
Fully charged
After Meals
Roborock Qrevo 5AE
350*353*96.5mm
340*487*519mm
Roborock Qrevo 5AE
Roborock Qrevo S
12000 Pa
Dual Anti-Tangle System
FlexiArm Mop
7000 Pa
All-Rubber Main Brush
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 12,000 Pa. Actual results may vary due to environmental factors. Suction power values may vary by country or region.
9. Compared to the Roborock Q7 Max. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
10.Based on internal testing carried out by the manufacturer, the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
11.Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
12.Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
13.Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
14.Certification No.PT/23/GEN/0046 by SGS. Actual results may vary depending on usage conditions.
