    this is a image this is a image
    Roborock Qrevo Curv
    Tangle-Free Cleaning, Effortless Elegance
    Buy Now
    Meet Roborock Qrevo Curv, blending elegance and innovation. The Dual Anti-Tangle System and AdaptiLift Chassis ensure exceptional performance by preventing hair tangles and adapting to various floor types for comprehensive, hassle-free cleaning. With 18,500 Pa HyperForce suction and FlexiArm Technology, every corner is spotless. Let Roborock Qrevo Curv bring warmth and unmatched performance to your home.
    No Tangles, Just Clean Floors
    No Tangles,
    Just Clean Floors
    Cleanliness
    Without a Snag
    Discover Roborock Qrevo Curv's revolutionary dual anti-tangle system with both main brush and side brush, perfect for handling long hair and pet-friendly homes. Enjoy tangle-free, hassle-free cleaning without constant brush maintenance.
    this is a image
    DuoDivide Main Brush
    The DuoDivide Brush features two parallel short bristle rollers with spiral blades that guide hairs towards the central dustbin inlet, where powerful suction swiftly removes it. The design prevents tangles and clogging, for effortless cleaning. SGS and TUV certified.
    Hair Removal Rate1
    100 %
    Hair Tangling Rate2
    0 %
    this is a image
    FlexiArm Arc Side Brush
    The unique arc-shaped asymmetric brush harnesses centrifugal force to prevent hair tangling, guiding it effortlessly to the bristle ends. SGS and TUV certified, this design ensures efficient and tangle-free cleaning.
    Hair Tangling Rate3
    0 %
    this is a image
    this is a image
    this is a image
    Easy-to-Maintain Omni-Wheel
    The upgraded omnidirectional wheel features a convenient brush next to the wheel that cleans it during use, making maintenance a breeze.
    this is a image
    Elite Power, Better Than Ever
    Elite Power,
    Better Than Ever
    Industry-Leading 18,500 Pa HyperForce
    Amp Up
    Your Cleaning
    Industry-leading 18,500 Pa HyperForce suction paired with DuoDivide bristle brush ensures that Roborock Qrevo Curv tackles tough cleaning challenges such as carpets and hard floor gaps, removing even the smallest particles.
    HyperForce Suction4
    18,500 Pa
    Hair Removal Rate on Carpet5
    99.5 %
    this is a image
    this is a image
    HyperForce Suction4
    18,500 Pa
    99.5 %
    FlexiArm Technology
    Cover Every Inch
    Roborock's exclusive FlexiArm Arc Side Brush and Edge Mopping System deliver exceptional cleaning coverage, eliminating blind spots and ensuring no dirt is left behind.
    Edge and Corner Coverage6
    100 %
    Along the Edge and Corner6
    0 mm
    When detecting corners, the arc side brush quickly extends to sweep away messes for thorough cleaning.
    FlexiArm Mop
    The extendable right-side mop precisely cleans along edges and adjusts dynamically to corners.
    FlexiArm Mop
    Dual Spinning Mops
    Leave Floors
    Picture-Perfect
    Achieve spotless floors effortlessly. Dual mops rotate with consistent pressure and humidity, effectively lifting and removing stains with ease.
    Spinning Speed7
    200 RPM
    Water Flow Options
    30 Levels
    Reach New Heights
    Reach New Heights
    AdaptiLift Chassis
    Uplift Your
    Cleaning Standards
    Elevate your cleaning with the industry-first8 AdaptiLift Chassis, featuring independently adjustable three-wheel control for versatile lift states. Elevate the entire chassis by 10mm9 or lift the front, rear, left, or right halves to adapt effortlessly to any home environment. The AdaptiLift Chassis ensures optimal cleaning coverage, easily navigating obstacles and different floor types.
    Roborock Qrevo Curv effortlessly handles high thresholds by automatically lifting its omni-wheel. It can overcome standard thresholds up to an impressive 3cm10 and even navigate complex double-layer thresholds up to 4cm11, the highest in the industry12, ensuring uninterrupted movement across various surfaces.
    Mid-to-Long-Pile Carpet Cleaning
    Clean mid-to-long-pile carpets with ease thanks to the AdaptiLift Chassis, which elevates the chassis by 10mm, allowing strong suction power to penetrate deep into carpet fibers without clogging. Enjoy cleaner carpets and superior cleaning results with Roborock Qrevo Curv.
    *The mid-to-long-pile carpet cleaning settings need to be activated manually in the Roborock app.
    Liftable Brush and Mops
    Tailored Solutions
    for Every Task
    For various cleaning needs, the brush and mops automatically lift to enhance effectiveness and prevent stains after cleaning.
    Chassis & Mops Lifted
    Mops Lifted
    Brush Lifted
    Brush & Mops Lifted
    10 mm
    Chassis Lifting
    Chassis Lifting
    10 mm
    Mop Lifting13
    Mop Lifting13
    Mops Lifted
    low-pile carpet
    Mops & Chassis Lifted
    Brush Lifted
    Mops Lifted Mops & Chassis Lifted Brush Lifted
    Vacuum-only
    Mop-only
    Carpet cleaning
    low-pile carpet
    Returning to dock
    Mop drying
    Where Elegance and Functionality Converge
    Where Elegance and
    Elegant Curved Aesthetics
    Designed for the
    Contemporary Home
    Roborock Qrevo Curv's dock features a smooth, rounded form with graceful curves, exuding softness and sophistication. Enhancing your home's aesthetic appeal, it embodies Roborock’s dedication to creating a pristine environment.
    75°C Hot Water Mop Washing
    Deep Clean,
    Maximum Hygiene
    Clean stubborn stains and greasy messes from mops without trouble using 75°C hot water14, perfect for kitchens and dining areas. The hot water eliminates over 99.99% of bacteria from the mops, ensuring optimal hygiene. With three adjustable temperature settings, you’re prepared for any cleaning scenario.
    Bacteria Removal Rate15
    99.99 %
    this is a image
    this is a image
    Intelligent Dirt Detection
    Enhanced
    Cleaning Excellence
    this is a image
    Re-Wash
    During mop washing, detection checks mop cleanliness, ensuring they are re-washed as needed for impeccable results.
    this is a image
    Re-Mop
    For areas with stubborn dirt and stains, the floors receive an additional mopping to guarantee a pristine finish.
    *The automatic re-mopping feature needs to be activated manually in the Roborock app.
    this is a image
    Re-Wash
    this is a image
    Re-Mop
    Zero-Touch Cleanliness
    The incorporated self-driven cleaning module uses rotating scrapers and hot water to effortlessly clean the dock base, eliminating the need for manual maintenance.
    Multifunctional Dock 3.0
    Minimum Maintenance with
    Maximum Convenience
    Warm Air Drying
    Auto Tank Refilling
    Detachable Base
    Warm Air Drying Dries the mops and dock base completely with 45°C of warm air16, preventing the growth of mold and unpleasant odors.
    Auto Dust Emptying Allows for up to 65 days without manual emptying.17
    Intelligent Features that Set the Standard
    that Set the
    Standard
    Say “Hello Rocky”
    for Help
    Say “Hello Rocky”for Help
    Just say "Hello Rocky" to start cleanups, adjust settings for the perfect cleanup, or summon the robot where it's needed, all without lifting a finger. Enjoy convenient cleaning with voice control, even offline, without needing WiFi or your phone to control the robot.
    Clean here
    Clean the kitchen
    Just vacuum
    Start and Pause Cleaning
    Cleanups
    by Call
    Specify Room Cleaning
    Adjust Cleaning Modes
    Auto Dust
    Emptying
    Mop Washing and Drying
    Cleanups
    by Call
    Auto Dust
    Emptying
    *Intelligent voice assistant is available in selected languages, please refer to the Roborock app for more information.
    Navigate Through
    Any Space
    Equipped with structured light and an RGB camera, the robot detects and avoids 62 object types across 20 categories18. It smoothly navigates around obstacles in both bright and dark environments, reducing the need for manual intervention.
    Objects Recognizable
    62 types
    this is a image this is a image this is a image this is a image
    PreciSense LiDAR Navigation
    Pet-Friendly
    Because Your
    Furry Friends
    Deserve the Best
    Quiet Cleaning
    Fitted with brushless motors and an optimized hardware design, Roborock Qrevo Curv significantly reduces noise while cleaning. Mopping noise levels as low as 55dB19 ensure a remarkably quiet cleaning experience so your pets stay relaxed and unbothered.
    Video Call
    Automatic Pet Recognition
    Pet Snaps
    Search for the Pet
    Clean As You Wish
    this is a image
    this is a image
    Roborock SmartPlan
    Technology
    Tailored cleaning modes to your habits, room types, and floor materials, Roborock SmartPlan intelligently generates cleaning modes, and adjusts settings and preferences automatically. Enjoy worry-free cleaning with no need for manual mode adjustments.
    this is a image
    Real-Time Cleaning
    Progress Display
    Experience enhanced cleaning management with the app's dynamic progress bar, easily tracking the robot's cleaning status. Save time with real-time updates directly on the homepage, ensuring maximum efficiency.
    this is a image
    Temporary Cleaning
    Always Within Reach
    Third-Party Voice Control
    Launcher Widgets
    Apple Watch App
    Matter Protocol
    Embrace the Future
    of Smart Living
    Discover endless possibilities with Matter protocol and Roborock Qrevo Curv. Enjoy uncomplicated control of your robot vacuum and other smart home devices, without worrying about compatibility issues. Embrace the ease and joy of a seamlessly connected smart home.
    Roborock Qrevo Curv with Refill and Drainage System
    Take Hands-Free to
    the Next Level
    On top of the maintenance-free dock features of the Roborock Qrevo Curv, we've introduced a refill and drainage variant, taking hands-free cleaning even further.
    Auto Water Refill and Drain
    Check Your Environment
    Strong Wi-Fi coverage
    Installation Requirements
    1. Maintain a space of approximately 32.2cm in height, 46cm in length, and 120cm in width.
    5. The installation distance for the water refill and outlet pipes is recommended within 6 meters of the dock. If this is not possible, please contact customer service for consultation.
    7. The pipeline layout should avoid passing through room doorways and corridors to prevent accidental breakage due to household traffic.
    8. Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of entanglement or missed cleaning.
    9. Before installation, disconnect the power supply of the dock. Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain any remaining water from the pipes, connect the water lines, and ensure there are no leaks before powering on.
    Auto Detergent Dispenser
    Detergent Tank Size
    600 ml
    Compact Design
    Save space with an impressive dock height of 32.1cm.
    *Products with a Refill and Drainage system are only available in certain regions and countries.
    • Customizable App Features
    • Carpet Boost+ System
    • Sensient Sensor Array
    • Adaptive Route Algorithms
    • Child Lock
    • Off-Peak Charging
    Roborock Qrevo Curv
    352*347*103 mm
    450*450*450 mm
    this is a image
    1. Certified No.PT/24/GEN/0244 by SGS. Actual results may vary according to the home environment.
    2. Certified No.PT/24/GEN/0243 by SGS. Actual results may vary according to the home environment.
    3. Certified No.PT/24/GEN/0245 by SGS. Actual results may vary according to the home environment.
    8. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
    9. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
    12. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
    13. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
    15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Test Report number:326033982a 001. Actual results may vary according to the home environment.
