    Next-Level
    Next-Level
    Suction Power
    22,000Pa
    HyperForce Suction Power6
    Hair Removal Rate on Carpet7
    Saros 10
    Saros 10
    Down To The Finest Detail
    Subscribe This is a image
    Buy Now This is a image
    The Thinnest Roborock
    to Make a Big Difference
    7.98 cm
    Ultra-Thin Design
    Ultra-Thin Design
    The RetractSense Navigation System lowers its LDS to pass under low-clearance areas and rises again in open spaces, all while featuring Roborock's slimmest design yet.1
    Meticulous LiDAR,
    Meticulous LiDAR,
    More Than Simply
    Rising and Retracting
    AdaptiLift Chassis
    AdaptiLift Chassis
    Overcome Barriers,
    Expand Possibilities
    Up to
    4cm
    Threshold Clearance2
    With a clearance of up to 4cm—featuring the industry-first AdaptiLift Chassis3 —Saros 10 effortlessly crosses doorways, managing 3cm thresholds with an additional 1cm track for double-layer thresholds, or up to 3cm for single-layer thresholds, ensuring uninterrupted cleanliness.
    Prevent Getting Stuck
    AdaptiLift Chassis adapts to different obstacles. Saros 10 automatically optimizes the best obstacle-crossing strategy by lifting its omni wheels and drive wheels, ensuring smooth, uninterrupted cleaning even in challenging situations.
    Saros 10 elevates the chassis up to 10mm on high-pile carpets, reducing suction port blockages from long fibers.4
    Hair Tangling?
    Divide and Conquer
    Divide and Conquer
    Hair Tangling5
    DuoDivide Main Brush
    The DuoDivide Anti-Tangle Brush transports collected hair to the dustbin inlet in the center, where the hair is stripped off and powerfully suctioned into the dustbin.
    Learn More About How the Dual Anti-Tangle System Works
    Hair Tangling5
    FlexiArm Riser Side Brush
    VibraRise 4.0 Mopping System
    Enhanced, in Pretty
    Much Every Way
    Mop, Unclip!
    Larger, Harder, Smarter
    The VibraRise 4.0 Mopping System features a denser, more absorbent mop that locks in moisture for effective stain removal. Dual sonic vibrating zones at 4,000 times/min each, up to 8N pressure, and a 26% larger vibration area ensures superior mopping performance.9
    26% Larger
    Mop Vibrating Area10
    Up to 8N
    Up to
    8N
    Downward Mopping Pressure11
    Up to 220 RPM
    Up to
    220 RPM
    Side Mop Speed12
    Side Mop Independent Lifting
    Edge-to-Edge
    Edge-to-Edge
    Coverage
    Edge and Corner Sweeping14
    0.51 mm
    Edge-Close Mopping14
    Adaptive Elevation
    Adaptive Elevation
    for Spills and Carpets
    For Spills15
    For Carpets
    Mop Removal For Carpets
    For Spills15
    • Side Brush Lifts
    • Main Brush Lifts
    • Mop Lowers
    • Vacuum Motor Stops
    For Carpets
    • Side Brush Lifts
    • Main Brush Lowers
    • Mop Lifts4
    • Vibrating Mop Removed
    • Main Brush Lowers
    • Side Brush Lifts
    Quadruple, Exceptional
    Saros 10 features an advanced perception system with front triple structured light, an RGB camera, and VertiBeam lateral structured light. It offers a wider obstacle-avoidance view, minimal blind spots, and clear detection near and far with swift response.
    Dodge Fast
    Clean Close
    VertiBeam lateral obstacle avoidance precisely measures the distance between the robot and side obstacles, ensuring accurate edge cleaning along furniture and objects.
    RockDock Ultra 2.0
    RockDock Ultra 2.0
    Clean Deeper, Charge Faster
    The RockDock Ultra 2.0 blends sleek design with practical convenience. It features an AG-treated tempered float glass lid that opens with a simple press, while the dust cover on the water tanks ensures lasting cleanliness.
    This is a image 80°C Dynamic Mop Washing16
    This is a image Auto Mop Detaching
    This is a image 60°C Heated Air Drying17
    This is a image 150-Min Fast Charging19
    This is a image 80°C Dock Self-Cleaning16
    This is a image Warm Water Tank Refilling
    The RockDock Ultra 2.0 uses adaptive water temperatures to tackle stains, preventing starch-based stickiness, melting oil stains, and sterilizing at high temperatures to remove 99.99% of Staphylococcus aureus and Escherichia coli from the mop after self-cleaning.18
    50°C
    60°C
    80°C
    For stubborn grease stains.16
    50°C
    60°C
    80°C
    RockDock Ultra 2.0 fully powers a 6400mAh battery in just 150 minutes. The dock intelligently adjusts the charge needed based on the remaining area, so you don't need to wait until it's fully charged.19
    The Quietest
    The Quietest
    Roborock Yet
    52 dB(A)
    Quiet Mopping Mode21
    72 dB(A)
    Dock Self-Emptying21
    Explore the Roborock App and Its Pet-Friendly Features
    Easy-to-Use App
    Tap, Tap, Clean
    Roborock SmartPlan 2.0
    Saros 10 intelligently identifies floor types and room categories, and customizes the optimal cleaning strategy based on each area and past cleaning habits.
    No Internet?
    No Internet?
    No Worries, It Still Works
    Cereal Spilled
    Busy Working
    Finished Cooking
    "Hello Rocky, clean here."
    Cereal Spilled
    Busy Working
    Finished Cooking
    As Always
    As Always
    Pick It Up
    Gather It In
    Strip It Off
    Suck It In
    Asymmetrical Spiral Arc
    Soft Rubber Baffle
    Longer Side Brush Bristles
    Saros 10 with Refill
    & Drainage System
    Auto Water Refill and Drain
    Check Your Environment
    Space Requirements
    Clean Water Inlet
    Power Plug
    Dirty Water Outlet
    More than 100cm
    More than 42cm
    More than 30.5cm
    Strong Wi-Fi Coverage
    Installation Requirements
    1. Reserve a space of at least: 30.5cm in height, 42cm in width, and 100cm in depth.
    5. The installation distance for the water refill and outlet pipes is recommended within 6 meters. If not, please contact customer service for consultation.
    6. The water pressure range is 0.1-0.4 MPa. If it exceeds 0.4 MPa, please use a pressure-reducing valve.
    8. Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of getting stuck or missing cleaning.
    Compact Design
    Seamlessly fits in your home environment and saves space with an impressive dock height of just 30cm.
    Your This is a image Furry Friends
    Deserve the Best
    Video Call
    Other Thoughtful Features
    Up to
    30
    Partitions Supported
    Automatic Map Correction
    Up to
    30
    Saros 10
    Robot (LDS Retracted)
    350 x 353 x 79.8 mm
    Robot (LDS Elevated)
    350 x 353 x 93.5 mm
    409 x 440 x 470 mm
    • Custom Cleaning Routines
    • Child Lock
    • Sensient Sensor Array
    • Roborock Carpet Boost+ System
    • Quiet Mopping
    2. Based on Roborock internal testing. This product is tested to cross thresholds up to 4cm, including a 3cm threshold plus an additional 1cm track on top for double-layer thresholds, or up to 3cm for single-layer thresholds. Actual results may vary depending on usage conditions.
