    Saros Z70
    A Robotic Cleaner,
    Now Also a Robotic Helper
    Recognize and Organize Socks? Toward the closet. Sandals? Toward the entrance rug. Crumpled tissues? Toward the Store Box*. The Saros Z70 identifies and relocates household items to their designated spots, as programmed in its software. *App connection and setup are required for the obstacle management feature. Actual performance may vary due to software updates and environmental factors. *Current recognizable and organizable objects include socks, sandals, crumpled tissues, and towels under 300g. New items will be added continually via firmware OTA updates.
    OmniGrip™
    OmniGrip™ is equipped with precision sensors, a camera, and an LED light, enabling it to determine its position, surroundings, and the weight of each object it grips. This ensures the mechanical arm operates with exceptional accuracy.
    AI-Powered Customization
    In addition to the 108 objects1 pre-programmed into the robotic vacuum, the Saros Z70 utilizes customizable AI-driven recognition technology, empowering users to define and label up to 50 new objects2 in the app for personalized interaction and enhanced functionality. *
    Safety and Privacy Powerful Yet Gentle The OmniGrip™ arm features a gentle-grip design, capable of securely holding objects without damage. A built-in weight sensor prevents it from lifting items over a safe threshold (300g3). For added convenience, the grip can be manually reversed to release objects effortlessly when needed. This thoughtful design balances strength and care, providing a secure hold while preventing excessive squeezing.
    Customize as You Need OmniGrip™ features are disabled by default and can be activated by users based on their specific needs.
    Engineering Marvel
    Roborock's Slimmest,
    Most Compact Design Yet
    7.98cm Ultra-Slim Design
    All the pioneering cleaning features of Roborock vacuums are present in the Saros Z70, along with its groundbreaking mechanical arm that delivers an unprecedented experience. Integrating these advanced features into Roborock’s slimmest-ever 7.98 cm4 design — with a mechanical arm occupying 10%5 of the space of previous models — required rigorous R&D and innovative engineering.
    Still the Reliable,
    All-Round Pioneer.
    VertiBeam Lateral Obstacle Avoidance Improved accuracy in recognizing unfolded cables and irregular walls & furniture.
    Navigation System 21 x Improved Sampling Frequency than LDS6
    Obstacle Recognition 108 types of Obstacles Recognizable7
    Dual Anti-Tangle System
    No Stuck, No Fuss
    FreeFlow™ Main Brush
    FlexiArm Riser Side Brush 0% Hair-tangling Rate8
    22,000 Pa HyperForce
    S7 Max Ultra 5500 Pa
    S8 MaxV Ultra 10000 Pa
    Saros Z70
    Clean Closer, and Closer
    100% Edge and Corner Coverage10
    0mm Along the Edge and Corner11
    FlexiArm Riser Mop
    Industry-first AdaptiLift Chassis12
    Built For Versatile Lifting
    Enhance your cleaning with the AdaptiLift Chassis, featuring independently adjustable three-wheel control for versatile lifting. Elevate the entire chassis or adjust the front, rear, left, or right halves independently to conquer complex home environments, ensuring optimal cleaning coverage.
    4 cm Maximum Double-Layer Thresholds Crossing13
    Mid-to-High-Pile Carpet
    U-Shaped Furniture Leg
    4 x Liftable Designs
    - 22 mm14 Maximum Mop Lifting
    - 10 mm15 Chassis Lifting
    Chassis Lifted
    Multifunctional Dock 4.0
    Auto Mop Removal
    2.5-Hour Fast Charge
    80℃ Hot Water Mop Washing
    Smart Re-Wash & Re-Mop
    Auto Detergent Dispenser
    Warm Water Tank Refilling
    55℃ Warm Air Drying
    Detachable Dock Base
    Auto Mop Removal
    When Vacuum-Only
    When Vacuum Carpet First
    99.99% Bacteria Removal Rate
    590ml Capacity
    Next-Level Intelligence
    Say “Hello Rocky” for Help
    Easy-to-Use App
    Tap. Tap. Clean.
    Roborock SmartPlan 2.0 One Tap to
    AI-Driven Cleaning
    This is a image Enjoy truly automated cleaning with Roborock SmartPlan mode. All you need is a tap in the app, and the robot automatically adjusts its settings based on AI-analyzed environments and cleaning history. It boosts suction and water volume for areas that need extra attention, reduces power during do-not-disturb hours, and cleans its mops after tackling bathrooms and kitchens.
    Pet-Friendly Intelligence
    Paw-some Sidekick for Pets
    Pet and Pet Area Recognition It stops its main brush and moves aside in advance when approaching your beloved pets to avoid frightening them. It will boost suction when cleaning around pet supplies for a thorough clean.17
    Broadly Compatible with
    Product Dimensions
    Saros Z70
    13.78 x 13.9 x 3.14 inches
    350 x 353 x 79.8 mm
    15.0 x 18.7 x 19.21 inches
    381 x 475 x 488 mm
    4. As of January 2025, the Saro Z70 is the thinnest model among Roborock's vacuum robots.
